egprod77
Aug 28, 2020Aspirant
ReadyNas RR230400 RAID 5 PARAMETERS
Hi I have a ReadyNas RR230400, the data is no longer accessible but still in the server, empty folder... I am doing a file search with R-Studio, what are the original Netgear X-RAID 5 settings, R...
- Aug 28, 2020
R-Studio won't work. Your NAS (which runs OS-6 firmware) uses BTRFS as the file system. R-Studio doesn't support that file system.
You'll need to use the more expensive ReclaiMe software. https://www.reclaime.com/
Sandshark
Aug 28, 2020Sensei
egprod77 wrote:Hi
I'm not sure what you mean by the underlined portion of the quote. If you mean you can still see the data via SSH but not via the GUI or SMB, then there are other ways to fix this.
