swaggerking
Jan 03, 2015Aspirant
ReadyNAS Tech Support Slow to Respond #24460879
Bought my first ReadyNAS 312 less than a month ago and already 2 Tech Support tickets. Going on 48 hours with this problem. Upgraded to 6.2.2 and then a couple days later I un-installed Netgear Survei...
mdgm-ntgr
Jan 03, 2015NETGEAR Employee Retired
Looking at your case notes it looks like support has fixed your system now. Did you do an OS re-install? Your admin password has been reset to the default one. It would be advisable for you to change the admin password.
The problem is one that others have seen recently. A symlink in /etc/apache2/sites-enabled was left behind which prevented apache2 (the http/s server service) from starting.
