cooperehlers
Aug 09, 2019Aspirant
ReadyNAS Ultra 2 - Time Machine restore not working
I am trying to restore a Macbook with a Time Machine backup on my NAS. The sparsebundle is accessable on the NAS when logging in with user: ReadyNAS and the password I set. But it says incorrect password when I try to use those details to restore the laptop. When I enter in the admin details I get the loading symbol then nothing.
Welcome to the Community!
Have you checked on this thread already? It discussed here some of the things that they have done on checking and accessing the Sparsebundle
HTH
Regards
- Marc_VNETGEAR Employee Retired
HTH
Regards
- cooperehlersAspirant
Hi,
Yes I had a look through that but there didn't seem to be a solution. Just looking at it now it would have helped if I read the very last post on the last page. I entered in the adress of the ReadyNAS folder, not the sparsebundle, in the 'other server' option. It worked then but still had a couple different issues with migration assistant. When i tried in recovery mode it worked.
Thanks!
