divisionmd
Nov 15, 2016Aspirant
ReadyNAS Ultra 2: how to recover data from RAID-1 disks?
Hello,
- I have a ReadyNas -> Netgear RNDU2120-100PES (check image below).
- It has a "blue light" - but the network port NIC seems totally dead. Not link at all. So my guess unit works well but the NIC port has crashed.
- Its two disks in the drive two 2TB disks.
- My plan is this - and wanted to double check with support first before i do this:
Step 1) Complete > I have cloned one of the drive to a copy - so i am not working on the original drive.
Step 2) Complete >I have connected the cloned drive to PC / Linux Debian wheezy.
Step 3) Complete >I can see the device in fdisk however i cant mount it - it needs "mdadm" i understand.
Step 4) Not yet > I am about to do this: Install "mdadm" and "vgscan" and run:
# mdadm --assemble --scan
# vgscan
# vgchange -a y
# mount /dev/c/c /mnt
Since that is what i have found out that i should do in this forum.
Is this correct? Then i will proceed.
Any input/help is most welcomed - need to urgently recover data.
Best regards,
Johan
You have an Ultra-2, not an RN102 - so your title isn't correct.
Your command sequence looks ok.
- mdgm-ntgrNETGEAR Employee Retired
Fixed the thread title.
It's advisable to check disk health and the state of the RAID array before proceeding to run the commands you mentioned.
- divisionmdAspirant
Hello mdgm,
- Can you update me on the commands i should run to check the "helath and state of RAID array" ?
- Also note - > i have one of the disks attached to a PC - should i attach both disk?
Best regards,
Johan
