Rogge66
Jan 09, 2018Aspirant
Readynas ultra 2 (RNDU 2000) can't connect to admin nor re-install OS
Hi I have a RNDU2000 Readynas ultra 2. Two disks, no backup :( It won't start, with radar it says sometimes disk ok and next boot "corrupt root". When disks is ok I can install it as a new but I ...
Jan 09, 2018Guru - Experienced User
First of all, you might want to test your disks in the windows PC using vendor tools (Lifeguard for Western Digital, Seatools for Seagate). They can find/test the disks even though Windows doesn't recognize the format.
You could also try R-linux for Windows, and see if it can read the files on the data volume.
Also, what are the SMART stats for the disks?
Rogge66 wrote:
Anyone who can explain to me how to "reset" the boot partition via SSH? Or install OS another way? USB? SSH?
I don't see much evidence here that an OS reinstall will do any good. The normal way is to use the front panel's boot menu (pages 14-15 here: http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf )
It will reset your admin password back to the factory default value (netgear1 for 4.2.x firmware). It will also reset your IP configuration to use DHCP, and remove any NIC bonding.
Rogge66
Haven't tried R-linux but vmware player with Debian as explained here, vmware Debian . Debian found the disks but could not read them.
SMART says "disk error" when bootin in windows.
Will try vendor program.
But shouldn't I be able to login to admin page?
Look at the picture, no error this time.
- StephenBJan 09, 2018Guru - Experienced User
Perhaps that will become more clear after we figure out your disk health.
What happens if you enter https://192.168.1.26/admin
Do you see the login prompt?
If so, what happens when you enter admin and the admin password?
- Rogge66Jan 09, 2018Aspirant
No I get "connection refused". I can ping it. I can SSH when rebooting it into "tech support" with root and the "secret" password. But my knowledge in linux is limited. Of course, Google is my friend, and I did some things I found on different threads in this forum. But nothing helped...
But file transfers work through windows file explorer? Do you have a backup of the data?
If the answer to both is no, try r-linux for windows as suggested above. Your data is certainly at risk.
You can also look at the SMART stats on windows. Acronis Drive Monitor is one utility that will do this - it's free, but you do need to disclose your email address to get it.
