denniske3
Mar 06, 2017Follower
ReadyNas Ultra 4 boots to certain % and stops further booting
Hi all,
I could be that this question was already raised before, howver I didn't find the proper solution for this.
Suddenly when I booted my Netgear Nas it would hang on a radom percentage when it was booting.
If I reboot the number would be a other percentage where it will get stuck on again.
The following things I've tried didn't helped:
- Removing one disk and try rebooting it.
- Check if the memory is still good inplace etc.
- numerous of atemps rebooting.
Note that the ready nas is not running the original Radiator OS but the Readynas OS 6.X.X
Does anybody have a proper solution for this or know what to do?
PS: I don't want to lose my data otherwise I would already tried a Factory Reset.
Your advise is more than welcome :)
1 Reply
- mdgm-ntgrNETGEAR Employee Retired
So you're running an OS that NETGEAR does not support running on your device, you don't want to lose your data and you haven't got a backup?
I've sent you a PM.
