PederMyhre
Aug 09, 2018Aspirant
ReadyNAS Ultra 4 Change defective HD still dead
Hello!
I have read all the topics about dead harddrives but i still dont understand the solution to my problem.
I have 4 disks running: RAID Level X-RAID2, 4 disks
Disk 2 went dead (I took ...
PederMyhre
Aug 10, 2018Aspirant
I'm running RAIDiator 4.2.31
The old disk's are Segate ST20000DL003 (In bay 1,3,4)
The new disk is Segate ST2000DM006 (In bay 2 )
In the disk status it's still ST20000DL003 in bay 2, but it should be ST2000DM006, and not showing temperature.
Aug 10, 2018Guru - Experienced User
FWIW, a Seagate Ironwolf would have been a better disk choice. Seagate DMs don't have a good track record with RAID. The HCL hasn't been updated for years now, so it isn't a useful guide anymore. You're better off getting a current NAS-purposed drive (Seagate Ironwolf or Western Digital Red) or an enterprise-class disk. I don't recommend desktop class drives for NAS use anymore.
I think the next step is to pull disk 2, and test it in a Windows PC with Seatools. You can connect it to the PC either with SATA or a USB adapter/dock.
- PederMyhreAug 16, 2018Aspirant
Hello again and thank's for the reply.
The first disk i tried was a new Segate Skyhawk, that didn't work, then i read in the compability list and got a Segate Baracuda that was in the list, but that did not work either, as showed in the picture in my last post. Now i got a WD red NAS disk and the same message as the Baracuda showed ut,
New disk detectet
Testing new disk
Ned disk passed the test
Volume will be rebuildt on disk 2
Then nothing more happens.
The nas is still showing the model number og the old disk that's been there for many years.
everything is the same as in the postet picture.
Now i tried three different new disks and still no progress..
Any ideas anyone?
- StephenBAug 16, 2018Guru - Experienced User
Try hovering over the both the volume icon and the disk s icon on the home page (the "ball" icons at the bottom), and see if you get a status that indicates the RAID array is syncing.
If you do see this, then I suggest waiting a while, and see if sync completes. Then reboot if the disk list still shows the wrong disk.
If you don't see this status, you could try powering down, and removing the power cable for a couple minutes. Then remove the new disk, boot the NAS, and try hot-inserting it one more time.
I did what you wrote just now.
When i startet the nas everything still looks like the picture i posted. In the Raidar tool i see that disk 2 is missing (Since i have not plugged it in yet) But in the nas the it says Segate .(Model number) .... Dead
Before shutdown the disk bubble said the same as in the picture, Segate ..(Modelnumber). Dead
In the volume bubble it is just a warning that the volume is not redundand
After shutdown, no power for 10 minutes, startup and inserting disk everything is just the same, same message in the bubbles and in the log as the picture.
Before shutdown now this wd red disk had been running for 4 days without any result (Same as the two other new drives).
I also get a message about error count increasing on disk 3 and i should replace this disk before it stop's working, but i cant do that before disk 2 is operative, the volume is still intact but probably not for very long.
What do i do now?
