MarcoScholten
Jul 09, 2014Aspirant
ReadyNas Ultra 4 disc failure replacement issue
Hi, I'm an existing user with a ReadyRas NV+ V2 and an Ultra 4 experiencing disc failure issues in the Ultra 4 setup in X-RAID2 with four 3TB HDD's (all Seagate). Disc 3 failed, replaced it with a 3TB...
Jul 10, 2014Guru - Experienced User
You can't. You can back up 4 TB to another NAS, and 3 TB to the WDC Red that isn't part of the array (disk 3).
MarcoScholten wrote: How do I make sure all remaining data is only stored on disc 1 and 4? Please advise.
But if you remove disk 1, disk 2, or disk 4 you will lose all your data. Of course you need another drive anyway, so perhaps buy a 2nd WDC Red ASAP, and start backing up what you can while you are waiting for it to arrive.
How full is the volume?
