MarcoScholten
Jul 09, 2014Aspirant
ReadyNas Ultra 4 disc failure replacement issue
Hi, I'm an existing user with a ReadyRas NV+ V2 and an Ultra 4 experiencing disc failure issues in the Ultra 4 setup in X-RAID2 with four 3TB HDD's (all Seagate). Disc 3 failed, replaced it with a 3TB...
vandermerwe
Jul 11, 2014Master
You will need to remove it, put it into a drive caddy and set it up as you have done with the USB drives you are using, then do a backup.
As StephenB has suggested, you might want to power down the NAS and clone disks 1,2 and 4. Of course you would need additional disks for this but if your data is important it may be worth it.
