HalbeEllgr
Oct 16, 2023Aspirant
ReadyNas Ultra 4 not on network, no access to admin page
Hello all, I've had my ReadyNas for some years now. Has been working fine but has been slowing down recently, I upgraded the RAM and all was working well. I tried to upgrade the Plex app but fou...
Oct 16, 2023Guru - Experienced User
HalbeEllgr wrote:
I can't get support from Netgear because the product Isn't registered to me ( I recently realised) and because of that, I can't get through their process.
All ReadyNAS are end of life (and the Ultra is over 10 years old, so long out of warranty). So no support from Netgear anymore.
Can you post a screenshot of the RAIDar screen?
Also, are you seeing the NAS in your router's attached device list?
Did you try pinging it?
HalbeEllgr
Thanks for your reply.
Here's the raidar snip. I can ping it and it shows on my router list.
Just can't access the admin page, it gets to the Netgear screen and sits there. Can't access via pc or android file manager.
- StephenBOct 16, 2023Guru - Experienced User
Thx - looks like it is also converted to OS-6. So Netgear would deny support in any event.
Do you have a backup of your data?
Are either the download logs or diagnostic links working? If you can get the logs, then I could take a look at them.
If you have ssh enabled, you could see if that lets you log in.
- HalbeEllgrOct 16, 2023Aspirant
I do not have an additional backup of data.
I can access logs & diagnostics.
SSH is something I've read about only recently, assume it's not enabled, but don't know how to check.
Have sent over logs via PM.
Cheers
