skpnsf
Dec 11, 2011Aspirant
ReadyNAS Ultra 4 Plus memory upgrade
Hello, We are enjoying our ReadyNAS Ultra 4 Plus more than we anticipated. We would like to upgrade the 1024 MB [DDR2] to the highest amount possible. Any tips on: Is this a fairly easy hardwar...
mdgm-ntgr
Dec 14, 2011NETGEAR Employee Retired
Things may be a bit more snappy with more memory, but the 98% full is not a problem (it's by design) as explained in this FAQ I referred to earlier: http://www.readynas.com/kb/faq/hardware/is_there_a_way_i_can_verify_if_my_memory_is_good
Caching uses up the memory but the memory is freed up when needed.
