shmulikw
Feb 06, 2022Aspirant
readynas ultra 6 failing to reboot when network cable attached
hi as the topic says the device wont reboot while attached to the network. i saw a solution suggesting to replace the power supply. before getting to it. didt someone found another and easier...
Sandshark
Feb 07, 2022Sensei
What do you mean by "fails to reboot"? It simply ignores the command, or the software seems to be stopping but the hardware never does the actual reset?
The NIC and the power on/off circuitry are powered by the same source, which is +5VSB (+5 Volts Standby), which is always on, even when the NAS is off (unless unplugged or switched off at the rear of the unit). Therefore, it's often the first section of the supply to go. If you have available a standard ATXV12 power supply, you can connect it externally in place of the internal one to see if that fixes it before you buy a replacement that fits internally (SFX format).
shmulikw
Feb 07, 2022Aspirant
thank you for the reply.
it just won't boot when the cable connected.
starts to boot after thefs check it reboots
one the network cable disconnected it works ok.
after booting it works ok even with the cable attached.
i can read the files
but when i try loading files it sometimes boots again.
i dotb have spare power supply
if that is most likely the solution
i"ll buy one
- StephenBFeb 07, 2022Guru - Experienced User
one the network cable disconnected it works ok.after booting it works ok even with the cable attached.
This doesn't sound like a power supply issue to me.
What firmware are you running on the NAS?
Do you have a backup of the data?
- SandsharkFeb 08, 2022Sensei
StephenB wrote:This doesn't sound like a power supply issue to me.
Certainly a very odd one if it is. Does it do the same thing regardless of which port is connected to your LAN?
- shmulikwFeb 08, 2022Aspirant
thank you all for the replies
the data is not backed up, but it is not something i can recover from other sources.
the FW as i recall is 4.2.31
it doesn't matter wich lan input is used
what can it be if not power supply problem?
