vertigo2712
Jun 18, 2012Aspirant
Readynas Ultra 6 freezes (case: 18799893)
About a week ago I bought a ReadyNas Ultra 6. I set it up, upgraded it to the latest available RAIDiator firmware 4.2.20 and installed 6 x 2TB Hitachi HUA722020ALA330 drives (from the compatibility li...
mdgm-ntgr
Jan 31, 2013NETGEAR Employee Retired
harmakhis you should open your own thread and contact support (please post your case number) so they can review your logs zip file (Status > Logs > Download all Logs) to help determine the cause of the problem. Your problem may have a different cause to the other user's.
Apparently the temperature is recorded as 50 degrees as temperatures below this level cannot be recorded accurately. So the temperature of the CPU would be at or below 50 degrees.
- Jan 17, 2024Retired_Member
