frusnet
Apr 14, 2014Aspirant
ReadyNAS Ultra 6 Plus.... 18TB -> 24TB
Hi, Currently using 6x3TB Seagate 3TB ST3000DM001 drives on a ReadyNAS Ultra 6 Plus. Not a very good drive though imo, had already 2 bad ones, curiously both were in slot No.2 of the NAS... wondered...
frusnet
StephenB wrote: If you are running dual redundancy, then it might be possible. It depends on the answers to the other questions mdgm asked.
Of course if you are running with no backups, then your data is generally at risk.
BTW, I had horrible reliability with Seagate drives in the past, so I switched to WD!
For ST4000NV000 it specifically says:
Seagate NAS HDDs provide the best-performing, highest-capacity storage for 1- to 5-bay NAS systems.
Mine is 6 bay, wonder if that means anything.
What I do is I usually get 2 extra drives just in case.
Wonder if that would be a problem with ST4000NV000 which is a NAS-specific drive in the future.
On the other hand ST4000DM000 being a desktop drive can be found more easily.
For ex. Newegg doesn't currently have that NAS drive, nor Seagate (its page can be reached from Google but not from Seagate
http://www.seagate.com/internal-hard-drives/
but it exists here:
http://www.seagate.com/internal-hard-drives/nas-drives/
.....that's what I meant.
Wonder if that's an abandoned line?
