fifer55
Apr 24, 2013Apprentice
ReadyNas Ultra 6 Plus CPU Upgrade - Various
Hello, This is a continuation to the upgrades I am doing on a ReadyNas Ultra 6 Plus (RNDP600U-200NAS) that I recently purchased. I decided to first upgrade the RAM. You can find what I choose, why ...
fifer55
Apr 26, 2013Apprentice
interested wrote: I know, that power consumption is larger by the processor Q6600.
how much is the difference in temperature ???
Comparition link http://www.cpu-world.com/Compare/705/Intel_Core_2_Duo_E7600_vs_Intel_Core_2_Quad_Q6600.html
Here is the first comparison I did. This is using the Intel Core 2 Duo E7600:
Then I killed the command and waited about 5 minutes:
The exact command I used was:
while true; do echo; done
Will pop the Intel Core 2 Quad Q6600 back in tomorrow.Excited to see what that does and HOPEFULLY it works!?
Seems the Intel Core 2 Duo E7600 runs cooler at 100% CPU utilization than STOCK CPU. Maybe it was also the thorough cleaning I did?
