RNNerd2's avatar
RNNerd2
ReadyNAS Ultra 6 Plus disconnects from network soon after booting.
Some weeks after upgrading to 6.10.7 firmware my ReadyNAS Ultra 6 Plus now disconnects within minutes after booting up. It makes it very difficult to administer and seemingly the only choice is to do...
  • StephenB's avatar
    Jul 28, 2022
    RNNerd2 wrote:
    The amount of RAM is what was shipped. From the specs it's as you guessed 1GB.
    However, the ReadyNAS's partner is a Business Pro Edition with 1GB which doesn't exhibit the same issue and is considerably more busy.
    Still, I recommend upgrading the RAM to at least 2 GB as the next step.  It's inexpensive and easy to do.
ProSupport for Business
