mpsharp
Aug 01, 2020Aspirant
ReadyNas Ultra 6 plus hangs after ~1 week (disks sleeping)
So I'd been encountering a problem where my NAS simply hangs with the LCD blank and non-responsive to a short press on the power button. Following another post here, I recently upgraded the memory to 4G and was hoping that would solve the problem. Unfortunately, a week later I encountered the same thing. This time though I did see the message on the LCD: Disks Sleeping. The machine was not responding to pings or the admin URL. Upon rebooting, I see nothing interesting in the logs. All the disks report being happy.
Firmware: 6.10.3
No apps installed
Last log message before the reboot:
Snapshot: Snapshot c_1596265229 was successfully created for share or LUN photos.
Any thoughts on how to troubleshoot?
Thanks
Did you check for a full OS partition?
mpsharp wrote:
3.74TB free out of 13.72. Just a little less than 30% free.
That's the data volume fullness. The OS partition is something else - a 4 GB partition that holds linux and the NAS configuration.
You can check it by downloading the log zip file, and then open up volume.log. Scroll down to the df -h section:
=== df -h === Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 701M 3.0G 19% / tmpfs 1.9G 0 1.9G 0% /dev/shm ...
/dev/md0 is the OS partition.
