xiaorrulez
Jun 27, 2012Aspirant
ReadyNas Ultra 6 Plus? Wait for the next one?
I have been looking into buying a NAS with 6 bays and is expandable. It looks like the ReadyNas Ultra 6 Plus is a bit dated with a E2160 CPU. I have also read that the pro series has been added to the...
xiaorrulez
Thanks for your quick reply! :( Unfortunately, I can't budget for the Pro 6, only enough for a Ultra 6 Plus.
Well, I'm going to order a Ultra 6 Plus and test my luck... Hope it's a E5300.
If you know... Whats the power consumption like while idle with 6 drives?
About the EOL :) I seem to had been reading the "replaced by" column... http://www.netgear.com/landing/en-us/eolbulletin.aspx
