thekidbass
Nov 06, 2022Tutor
Readynas Ultra 6 (RNDU6000) -"Error No Disks Detected" after Memory Test
I have an Readynas Ullra 6 (RDNU6000) with 6x3TB installed. RAIDiator ver 4.2.31. Flex-RAID level-0. After viewing post from Mook1 "Ultra 6 Memory Upgrade Verification", post 1125490, I wanted to up...
thekidbass
Nov 06, 2022Tutor
thekidbass
Nov 06, 2022Tutor
I just noticed that in my router's GUI, prior to disconnecting the ethernet, power cable to do the memory upgrade, I had the adress reservation of this NAS-Ultra 6, with Name "nas-EB-17-B6. After reconnecting the ethernet cable, the device name has now changed to "nas-EB-17-B7" which should not have happen. Not sure if this relates at all with the current problem "Error no disks detected" after the memory test. Also, if you look at the photo attached, the RIADar window no longer shows the model number, or firmware version like it used to prior to this problem I'm having. I now can't access the web GUI as well.
