thekidbass
Nov 06, 2022Tutor
Readynas Ultra 6 (RNDU6000) -"Error No Disks Detected" after Memory Test
I have an Readynas Ullra 6 (RDNU6000) with 6x3TB installed. RAIDiator ver 4.2.31. Flex-RAID level-0. After viewing post from Mook1 "Ultra 6 Memory Upgrade Verification", post 1125490, I wanted to up...
michaelkenward
Nov 06, 2022Guru - Experienced User
This is a ReadyNAS product.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
ReadyNAS Network Storage: Official NETGEAR Community
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
thekidbass
Nov 06, 2022Tutor
michaelkenward. I just mentioned the router situation but the problem at had is my Reaynas Ultra 6 Error-"No Disks Detected" and am stuck without being able to resolve it.
- michaelkenwardNov 06, 2022Guru - Experienced User
thekidbass wrote:
..... but the problem at had is my Reaynas Ultra 6 Error-"No Disks Detected" and am stuck without being able to resolve it.
That's why I told you that this is the wrong place for help with your problem.
- thekidbassNov 06, 2022Tutor
All the posts that I have been reading on this Netgear community site has been about problems with Readynas issues. So now you are confusing me.
You have a problem with a Readynas Ultra 6 (RNDU6000).
You have put your messages in a section about Nighthawk WiFi Routers.
Nighthawk Wifi routers have very little, if anything, in common with Readynas.
People who own Readynas are unlikely to read any messages that appear here.
The Netgear support people who help with Readynas will keep an eye on the Readynas sections.
