jasonamhicks
Dec 29, 2022Aspirant
READYNAS ultra 6
Unable to reset readynas OS via boot menu to allow factory password reset. current password unknown email registered is no longer available Any help is appreciated
Dec 30, 2022Guru - Experienced User
The process is documented on pages 28-29 here:
Make sure you do the OS reinstall (the factory default will destroy your data).
If you are running OS 4.2.x, the password will be reset to netgear1. If you have converted the NAS to run OS-6, then it will be reset to password.
