jasonamhicks
Dec 29, 2022Aspirant
READYNAS ultra 6
Unable to reset readynas OS via boot menu to allow factory password reset. current password unknown email registered is no longer available Any help is appreciated
Dec 30, 2022Guru - Experienced User
The process is documented on pages 28-29 here:
Make sure you do the OS reinstall (the factory default will destroy your data).
If you are running OS 4.2.x, the password will be reset to netgear1. If you have converted the NAS to run OS-6, then it will be reset to password.
jasonamhicks
Jan 08, 2023Aspirant
Hi Stephen,
Appreciate the reply thank you.
Have followed the OS reinstall, however have been unable to log in to the device using the default username and password.
have tried each of the passwords below.
Any other ideas?
Thanks in advance,
Jason
