jasonamhicks
Dec 29, 2022Aspirant
READYNAS ultra 6
Unable to reset readynas OS via boot menu to allow factory password reset. current password unknown email registered is no longer available Any help is appreciated
Dec 30, 2022Guru - Experienced User
The process is documented on pages 28-29 here:
Make sure you do the OS reinstall (the factory default will destroy your data).
If you are running OS 4.2.x, the password will be reset to netgear1. If you have converted the NAS to run OS-6, then it will be reset to password.
jasonamhicks
Jan 08, 2023Aspirant
Should add;
I am using admin as the user name.
Any other defaults you know of?
- SandsharkJan 09, 2023Sensei
Those are the only two default passwords for your NAS. Really old firmware from other models might use infrant1, but the Ultra6 came out after Netgear acquired Infrant.
Try using an incognito window on the browser. If you previously saved a password (which is now wrong), that could be the issue. An incognito window won't use any saved password.
