aace
Dec 23, 2025Aspirant
Readynas Ultra 6
I guess I spoke to soon. After using my NAS for a day I shut it down. The next day it would not boot. Just displays ReadyNAS. It may not have shutdown clean. I'm not sure how I got past it before...
Dec 23, 2025Guru - Experienced User
aace wrote:I removed the drive.
Will not load boot menu.
Will not boot usb recovery.
Swapped Power supply.
You might also want to check that the memory is seated.
- aaceDec 23, 2025Aspirant
Did that, forgot to list it.
- StephenBDec 23, 2025Guru - Experienced User
When you powered up again, was it still stuck on ReadyNAS?
Yes everything has had the same result. Any idea what the jumpers on the MB do? I did see a VGA connection. It would be nice to see what it's doing.
