aace
Dec 23, 2025Aspirant
Readynas Ultra 6
I guess I spoke to soon. After using my NAS for a day I shut it down. The next day it would not boot. Just displays ReadyNAS. It may not have shutdown clean. I'm not sure how I got past it before...
Dec 23, 2025Guru - Experienced User
aace wrote:I removed the drive.
Will not load boot menu.
Will not boot usb recovery.
Swapped Power supply.
You might also want to check that the memory is seated.
aace
Did that, forgot to list it.
- StephenBDec 23, 2025Guru - Experienced User
When you powered up again, was it still stuck on ReadyNAS?
- aaceDec 23, 2025Aspirant
Yes everything has had the same result. Any idea what the jumpers on the MB do? I did see a VGA connection. It would be nice to see what it's doing.
I don't, Sandshark might
