Glenn3193
Dec 08, 2023Aspirant
ReadyNAS Ultra4 - what can I do with it?
HI, I have a ReadyNAS Ultra 4 purchased in early 2013. I have been away for 2+ years (in the UK) and came back to find that I can not communicate with the NAS. Security issue I think. When I left it...
Dec 30, 2023Guru - Experienced User
Glenn3193 wrote:
Any ideas on how to access the Ultra4 to install what you recommend?
The first step is to make a temporary change to the FireFox settings so you can access Frontview. That change is to set security.tls.version.min to 1 (browse to about:config and search for the setting).
Once you can get into Frontview, you have two options:
The first option is to keep using 4.2.x firmware. If you do that, then you should first update the firmware to 4.2.31 (if it is running something older), and then install this add-on:
The second (and IMO better) option is to convert the NAS to run OS-6, using the instructions in the the 4th post of this discussion thread.
Glenn3193
Dec 31, 2023Aspirant
Hi Stephen,
Thanks so much. I am ignorant of a lot of security stuff (TLS 1.0 etc), but was able to get to Frontview (the NAS was on 4.2.31 already) and install the add-on. Doing this has taught me some things. Agree that this is temporary and that the best solution is to move to OS6.
Thanks again for all your help.
Btw, why can't I access folders "c" and "home" and what is in them?
Best,
Glenn
- StephenBDec 31, 2023Guru - Experienced User
"C" is the entire data volume. You actually can browse it if you
- set the admin password to something other than the default netgear1
- use the NAS admin credentials in file explorer
If you do that, you'll see all the shares (and home). These aren't duplicates, it's just another path to get to the same folders. Using admin credentials to access NAS shares is discouraged. but there are some times when it is useful.
"Home" is where the private "home" folders for each NAS account are placed. These are folders that only that account (and the NAS admin) can access. While the "home" folder feature makes sense for businesses, I think home users are better off not using it. Those folders can be challenging to back up/restore.
- jkalinaftwFeb 10, 2024Aspirant
I've gone ahead and installed Debian12/OpenMediaVault but currently troubleshooting the same poor ethernet performance no different than what is observed when running ReadyNAS4/6. Anyone have thoughts on how to achieve gig speeds?
- StephenBFeb 10, 2024Guru - Experienced User
What speeds are you seeing?
Do you have an Ultra 4? If not, what model do you have?
