Glenn3193
Dec 08, 2023Aspirant
ReadyNAS Ultra4 - what can I do with it?
HI, I have a ReadyNAS Ultra 4 purchased in early 2013. I have been away for 2+ years (in the UK) and came back to find that I can not communicate with the NAS. Security issue I think. When I left it...
Dec 31, 2023Guru - Experienced User
Glenn3193 wrote:
Btw, why can't I access folders "c" and "home" and what is in them?
"C" is the entire data volume. You actually can browse it if you
- set the admin password to something other than the default netgear1
- use the NAS admin credentials in file explorer
If you do that, you'll see all the shares (and home). These aren't duplicates, it's just another path to get to the same folders. Using admin credentials to access NAS shares is discouraged. but there are some times when it is useful.
"Home" is where the private "home" folders for each NAS account are placed. These are folders that only that account (and the NAS admin) can access. While the "home" folder feature makes sense for businesses, I think home users are better off not using it. Those folders can be challenging to back up/restore.
jkalinaftw
Feb 10, 2024Aspirant
I've gone ahead and installed Debian12/OpenMediaVault but currently troubleshooting the same poor ethernet performance no different than what is observed when running ReadyNAS4/6. Anyone have thoughts on how to achieve gig speeds?
- StephenBFeb 10, 2024Guru - Experienced User
What speeds are you seeing?
Do you have an Ultra 4? If not, what model do you have?
- jkalinaftwFeb 10, 2024Aspirant
StephenB: yes, this is an Ultra4 running the latest Debian12+OpenMediaVault. Here are some stats from the system. the OS is installed to a usb stick (64gb), 4GB of memory as well.
XXXXXXXXXX@readynas01:~$ ./speedtest-cli
Retrieving speedtest.net configuration...
Testing from AT&T Internet Services (X.X.X.X)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Nitel (Atlanta, GA) [8.85 km]: 7.848 ms
Testing download speed................................................................................
Download: 311.67 Mbit/s
Testing upload speed......................................................................................................
Upload: 231.25 Mbit/sinternal network transfers are just as slow.
[ 18.646931] sky2 0000:01:00.0 enp1s0: Link is up at 1000 Mbps, full duplex, flow control rx
enp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet X.X.X.X netmask 255.255.255.0 broadcast X.X.X.X
ether a0:21:b7:c1:63:32 txqueuelen 1000 (Ethernet)
RX packets 331219 bytes 413887589 (394.7 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 59159 bytes 156263111 (149.0 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 16------------memory-----------------------------------
XXXXXXXXX@readynas01:~$ free -m
total used free shared buff/cache available
Mem: 3905 580 3072 172 644 3324
Swap: 975 0 975----------additional network information---------------------
XXXXXX@readynas01:~$ sudo lshw -class network
*-network
description: Ethernet interface
product: 88E8057 PCI-E Gigabit Ethernet Controller
vendor: Marvell Technology Group Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: enp1s0
version: 10
serial: a0:21:b7:c1:63:32
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm vpd msi pciexpress bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 duplex=full ip=192.168.2.20 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:26 memory:feadc000-feadffff ioport:d800(size=256) memory:feae0000-feafffff
*-network DISABLED
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 10
serial: a0:21:b7:c1:63:33
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 latency=0 link=no multicast=yes port=twisted pair
resources: irq:27 memory:febdc000-febdffff ioport:e800(size=256) memory:febe0000-febfffff - jkalinaftwFeb 10, 2024Aspirant
not sure if my previous post was deleted. but let me try again.
System: ReadyNAS Ultra4 , 4GB memory, 64gb USB install drive seeing slow network speeds. running debian12 and OpenMediaVault. these speeds seem the same as when running ReadyOS
XXXXXXX@readynas01:~$ sudo lshw -class network
*-network
physical id: 0
version: 10
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 duplex=full ip=X.X.X.X latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
*-network DISABLED
physical id: 0
version: 10
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
resources: irq:27 memory:febdc000-febdffff ioport:e800(size=256) memory:febe0000-febfffff - StephenBFeb 11, 2024Guru - Experienced User
Can you measure internal network speeds with iperf3?
What speedtest result do you get on a PC?
- jkalinaftwFeb 11, 2024Aspirant
ok. I am using two systems in this scenario for the iperf3 - readynas01 (the readynas) and plexk8s01 (vm)
xxxxxxxxx@readynas01:~$ iperf3 -c ip.of.vm
Connecting to host ip.of.vm, port 5201
[ 5] local 192.168.x.x port 56748 connected to 192.168.x.x port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 115 MBytes 961 Mbits/sec 0 450 KBytes
[ 5] 1.00-2.00 sec 112 MBytes 943 Mbits/sec 0 518 KBytes
[ 5] 2.00-3.00 sec 112 MBytes 937 Mbits/sec 0 518 KBytes
[ 5] 3.00-4.00 sec 113 MBytes 947 Mbits/sec 13 434 KBytes
[ 5] 4.00-5.00 sec 112 MBytes 943 Mbits/sec 13 413 KBytes
[ 5] 5.00-6.00 sec 111 MBytes 934 Mbits/sec 0 450 KBytes
[ 5] 6.00-7.00 sec 112 MBytes 943 Mbits/sec 0 468 KBytes
[ 5] 7.00-8.00 sec 110 MBytes 921 Mbits/sec 0 488 KBytes
[ 5] 8.00-9.00 sec 111 MBytes 929 Mbits/sec 0 491 KBytes
[ 5] 9.00-10.00 sec 112 MBytes 944 Mbits/sec 0 491 KBytes
[ 5] 0.00-10.00 sec 1.09 GBytes 940 Mbits/sec 26 sender
[ 5] 0.00-10.01 sec 1.09 GBytes 938 Mbits/sec receiveriperf Done.
xxxxxxx@plexk8s01:~$ iperf3 -c ip.of.readynas
Connecting to host x.x.x.x, port 5201
[ 5] local 192.168.x.x port 45924 connected to 192.168.x.x port 5201[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 116 MBytes 970 Mbits/sec 0 3.99 MBytes
[ 5] 1.00-2.00 sec 111 MBytes 933 Mbits/sec 541 2.80 MBytes
[ 5] 2.00-3.00 sec 111 MBytes 933 Mbits/sec 0 3.05 MBytes
[ 5] 3.00-4.00 sec 112 MBytes 944 Mbits/sec 0 3.27 MBytes
[ 5] 4.00-5.00 sec 112 MBytes 944 Mbits/sec 0 3.45 MBytes
[ 5] 5.00-6.00 sec 112 MBytes 944 Mbits/sec 0 3.59 MBytes
[ 5] 6.00-7.00 sec 111 MBytes 933 Mbits/sec 0 3.71 MBytes
[ 5] 7.00-8.00 sec 112 MBytes 944 Mbits/sec 0 3.80 MBytes
[ 5] 8.00-9.00 sec 112 MBytes 944 Mbits/sec 0 3.85 MBytes
[ 5] 9.00-10.00 sec 111 MBytes 933 Mbits/sec 75 2.79 MBytes
[ 5] 0.00-10.00 sec 1.10 GBytes 942 Mbits/sec 616 sender
[ 5] 0.00-10.02 sec 1.10 GBytes 940 Mbits/sec receiveriperf Done.
test from VM to another VM
xxxxxxxx@plexk8s01:~$ iperf3 -c ip.of.other.vm
Connecting to host 192.168.X.X, port 5201
[ 5] local 192.168.X.X port 40112 connected to 192.168.X.X port 5201
[ 5] 0.00-1.00 sec 115 MBytes 964 Mbits/sec 0 3.15 MBytes
[ 5] 1.00-2.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 2.00-3.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 3.00-4.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 4.00-5.00 sec 111 MBytes 933 Mbits/sec 0 3.15 MBytes
[ 5] 5.00-6.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 6.00-7.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 7.00-8.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 8.00-9.00 sec 111 MBytes 933 Mbits/sec 0 3.15 MBytes
[ 5] 9.00-10.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 0.00-10.00 sec 1.10 GBytes 944 Mbits/sec 0 sender
[ 5] 0.00-10.03 sec 1.10 GBytes 941 Mbits/sec receiveriperf Done.
and forgot to add these messages which were in syslog.
[71444.451681] sky2 0000:01:00.0: error interrupt status=0x40000008
[71444.452837] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71664.010459] sky2 0000:01:00.0: error interrupt status=0x40000008
[71664.011681] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71666.432110] sky2 0000:01:00.0: error interrupt status=0x40000008
[71666.433435] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71755.367047] sky2 0000:01:00.0: error interrupt status=0x40000008
[71755.368292] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71755.394729] sky2 0000:01:00.0: error interrupt status=0x40000008
[71755.396113] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71758.311831] sky2 0000:01:00.0: error interrupt status=0x40000008
[71758.313278] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71762.421319] sky2 0000:01:00.0: error interrupt status=0x40000008
[71762.422826] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71929.470124] sky2 0000:01:00.0: error interrupt status=0x40000008
[71929.471553] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71937.104242] sky2 0000:01:00.0: error interrupt status=0x40000008
[71937.105503] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[72105.168733] sky2 0000:01:00.0: error interrupt status=0x40000008
[72105.169993] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[72112.722609] sky2 0000:01:00.0: error interrupt status=0x40000008
[72112.724123] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996 - jkalinaftwFeb 11, 2024Aspirant
one more note. I also downloaded the cmdline version of fast.com and see these results
------------------------------------------------readynas ultra 4-----------------------------------------------------
xxxxxxx@readynas01:~$ ./fast
-> 199.32 Mbps-----------------another vm/system on same network and switch-------------------------------
sysadm@single-malt:~$ ./fast
-> 796.71 Mbps---------------------------------------------------------------------------------------------------------------------------------
root@readynas01:~# dmidecode --type 1
# dmidecode 3.4
Getting SMBIOS data from sysfs.
SMBIOS 2.6 present.Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: NETGEAR
Product Name: ReadyNAS
Version: 08/23/2011 ReadyNAS-NVX-V2 V1.10
Serial Number:
UUID: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Wake-up Type: Power Switch
SKU Number:
Family: - StephenBFeb 12, 2024Guru - Experienced User
This looks like normal gigabit performance to me (~940 mbits/sec).
So I don't understand what problem you are trying to solve. Is the issue really about file transfer speed?
