Glenn3193
Dec 08, 2023Aspirant
ReadyNAS Ultra4 - what can I do with it?
HI, I have a ReadyNAS Ultra 4 purchased in early 2013. I have been away for 2+ years (in the UK) and came back to find that I can not communicate with the NAS. Security issue I think. When I left it...
Feb 10, 2024Guru - Experienced User
jkalinaftw wrote:
I've gone ahead and installed Debian12/OpenMediaVault but currently troubleshooting the same poor ethernet performance no different than what is observed when running ReadyNAS4/6. Anyone have thoughts on how to achieve gig speeds?
What speeds are you seeing?
Do you have an Ultra 4? If not, what model do you have?
jkalinaftw
Feb 10, 2024Aspirant
StephenB: yes, this is an Ultra4 running the latest Debian12+OpenMediaVault. Here are some stats from the system. the OS is installed to a usb stick (64gb), 4GB of memory as well.
XXXXXXXXXX@readynas01:~$ ./speedtest-cli
Retrieving speedtest.net configuration...
Testing from AT&T Internet Services (X.X.X.X)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Nitel (Atlanta, GA) [8.85 km]: 7.848 ms
Testing download speed................................................................................
Download: 311.67 Mbit/s
Testing upload speed......................................................................................................
Upload: 231.25 Mbit/s
internal network transfers are just as slow.
[ 18.646931] sky2 0000:01:00.0 enp1s0: Link is up at 1000 Mbps, full duplex, flow control rx
enp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet X.X.X.X netmask 255.255.255.0 broadcast X.X.X.X
ether a0:21:b7:c1:63:32 txqueuelen 1000 (Ethernet)
RX packets 331219 bytes 413887589 (394.7 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 59159 bytes 156263111 (149.0 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 16
------------memory-----------------------------------
XXXXXXXXX@readynas01:~$ free -m
total used free shared buff/cache available
Mem: 3905 580 3072 172 644 3324
Swap: 975 0 975
----------additional network information---------------------
XXXXXX@readynas01:~$ sudo lshw -class network
*-network
description: Ethernet interface
product: 88E8057 PCI-E Gigabit Ethernet Controller
vendor: Marvell Technology Group Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: enp1s0
version: 10
serial: a0:21:b7:c1:63:32
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm vpd msi pciexpress bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 duplex=full ip=192.168.2.20 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:26 memory:feadc000-feadffff ioport:d800(size=256) memory:feae0000-feafffff
*-network DISABLED
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 10
serial: a0:21:b7:c1:63:33
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 latency=0 link=no multicast=yes port=twisted pair
resources: irq:27 memory:febdc000-febdffff ioport:e800(size=256) memory:febe0000-febfffff
