Glenn3193
Dec 08, 2023Aspirant
ReadyNAS Ultra4 - what can I do with it?
HI, I have a ReadyNAS Ultra 4 purchased in early 2013. I have been away for 2+ years (in the UK) and came back to find that I can not communicate with the NAS. Security issue I think. When I left it...
jkalinaftw
Feb 10, 2024Aspirant
not sure if my previous post was deleted. but let me try again.
System: ReadyNAS Ultra4 , 4GB memory, 64gb USB install drive seeing slow network speeds. running debian12 and OpenMediaVault. these speeds seem the same as when running ReadyOS
XXXXXXX@readynas01:~$ sudo lshw -class network
*-network
description: Ethernet interface
product: 88E8057 PCI-E Gigabit Ethernet Controller
vendor: Marvell Technology Group Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: enp1s0
version: 10
serial: a0:21:b7:c1:63:32
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm vpd msi pciexpress bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 duplex=full ip=X.X.X.X latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:26 memory:feadc000-feadffff ioport:d800(size=256) memory:feae0000-feafffff
*-network DISABLED
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 10
serial: a0:21:b7:c1:63:33
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
configuration: autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 latency=0 link=no multicast=yes port=twisted pair
resources: irq:27 memory:febdc000-febdffff ioport:e800(size=256) memory:febe0000-febfffff
Feb 11, 2024Guru - Experienced User
Can you measure internal network speeds with iperf3?
What speedtest result do you get on a PC?
- jkalinaftwFeb 11, 2024Aspirant
ok. I am using two systems in this scenario for the iperf3 - readynas01 (the readynas) and plexk8s01 (vm)
xxxxxxxxx@readynas01:~$ iperf3 -c ip.of.vm
Connecting to host ip.of.vm, port 5201
[ 5] local 192.168.x.x port 56748 connected to 192.168.x.x port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 115 MBytes 961 Mbits/sec 0 450 KBytes
[ 5] 1.00-2.00 sec 112 MBytes 943 Mbits/sec 0 518 KBytes
[ 5] 2.00-3.00 sec 112 MBytes 937 Mbits/sec 0 518 KBytes
[ 5] 3.00-4.00 sec 113 MBytes 947 Mbits/sec 13 434 KBytes
[ 5] 4.00-5.00 sec 112 MBytes 943 Mbits/sec 13 413 KBytes
[ 5] 5.00-6.00 sec 111 MBytes 934 Mbits/sec 0 450 KBytes
[ 5] 6.00-7.00 sec 112 MBytes 943 Mbits/sec 0 468 KBytes
[ 5] 7.00-8.00 sec 110 MBytes 921 Mbits/sec 0 488 KBytes
[ 5] 8.00-9.00 sec 111 MBytes 929 Mbits/sec 0 491 KBytes
[ 5] 9.00-10.00 sec 112 MBytes 944 Mbits/sec 0 491 KBytes
[ 5] 0.00-10.00 sec 1.09 GBytes 940 Mbits/sec 26 sender
[ 5] 0.00-10.01 sec 1.09 GBytes 938 Mbits/sec receiveriperf Done.
xxxxxxx@plexk8s01:~$ iperf3 -c ip.of.readynas
Connecting to host x.x.x.x, port 5201
[ 5] local 192.168.x.x port 45924 connected to 192.168.x.x port 5201[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 116 MBytes 970 Mbits/sec 0 3.99 MBytes
[ 5] 1.00-2.00 sec 111 MBytes 933 Mbits/sec 541 2.80 MBytes
[ 5] 2.00-3.00 sec 111 MBytes 933 Mbits/sec 0 3.05 MBytes
[ 5] 3.00-4.00 sec 112 MBytes 944 Mbits/sec 0 3.27 MBytes
[ 5] 4.00-5.00 sec 112 MBytes 944 Mbits/sec 0 3.45 MBytes
[ 5] 5.00-6.00 sec 112 MBytes 944 Mbits/sec 0 3.59 MBytes
[ 5] 6.00-7.00 sec 111 MBytes 933 Mbits/sec 0 3.71 MBytes
[ 5] 7.00-8.00 sec 112 MBytes 944 Mbits/sec 0 3.80 MBytes
[ 5] 8.00-9.00 sec 112 MBytes 944 Mbits/sec 0 3.85 MBytes
[ 5] 9.00-10.00 sec 111 MBytes 933 Mbits/sec 75 2.79 MBytes
[ 5] 0.00-10.00 sec 1.10 GBytes 942 Mbits/sec 616 sender
[ 5] 0.00-10.02 sec 1.10 GBytes 940 Mbits/sec receiveriperf Done.
test from VM to another VM
xxxxxxxx@plexk8s01:~$ iperf3 -c ip.of.other.vm
Connecting to host 192.168.X.X, port 5201
[ 5] local 192.168.X.X port 40112 connected to 192.168.X.X port 5201
[ 5] 0.00-1.00 sec 115 MBytes 964 Mbits/sec 0 3.15 MBytes
[ 5] 1.00-2.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 2.00-3.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 3.00-4.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 4.00-5.00 sec 111 MBytes 933 Mbits/sec 0 3.15 MBytes
[ 5] 5.00-6.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 6.00-7.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 7.00-8.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 8.00-9.00 sec 111 MBytes 933 Mbits/sec 0 3.15 MBytes
[ 5] 9.00-10.00 sec 112 MBytes 944 Mbits/sec 0 3.15 MBytes
[ 5] 0.00-10.00 sec 1.10 GBytes 944 Mbits/sec 0 sender
[ 5] 0.00-10.03 sec 1.10 GBytes 941 Mbits/sec receiveriperf Done.
and forgot to add these messages which were in syslog.
[71444.451681] sky2 0000:01:00.0: error interrupt status=0x40000008
[71444.452837] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71664.010459] sky2 0000:01:00.0: error interrupt status=0x40000008
[71664.011681] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71666.432110] sky2 0000:01:00.0: error interrupt status=0x40000008
[71666.433435] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71755.367047] sky2 0000:01:00.0: error interrupt status=0x40000008
[71755.368292] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71755.394729] sky2 0000:01:00.0: error interrupt status=0x40000008
[71755.396113] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71758.311831] sky2 0000:01:00.0: error interrupt status=0x40000008
[71758.313278] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71762.421319] sky2 0000:01:00.0: error interrupt status=0x40000008
[71762.422826] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71929.470124] sky2 0000:01:00.0: error interrupt status=0x40000008
[71929.471553] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[71937.104242] sky2 0000:01:00.0: error interrupt status=0x40000008
[71937.105503] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[72105.168733] sky2 0000:01:00.0: error interrupt status=0x40000008
[72105.169993] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996
[72112.722609] sky2 0000:01:00.0: error interrupt status=0x40000008
[72112.724123] sky2 0000:01:00.0 enp1s0: rx error, status 0x7ffc0001 length 996 - jkalinaftwFeb 11, 2024Aspirant
one more note. I also downloaded the cmdline version of fast.com and see these results
------------------------------------------------readynas ultra 4-----------------------------------------------------
xxxxxxx@readynas01:~$ ./fast
-> 199.32 Mbps-----------------another vm/system on same network and switch-------------------------------
sysadm@single-malt:~$ ./fast
-> 796.71 Mbps---------------------------------------------------------------------------------------------------------------------------------
root@readynas01:~# dmidecode --type 1
# dmidecode 3.4
Getting SMBIOS data from sysfs.
SMBIOS 2.6 present.Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: NETGEAR
Product Name: ReadyNAS
Version: 08/23/2011 ReadyNAS-NVX-V2 V1.10
Serial Number:
UUID: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Wake-up Type: Power Switch
SKU Number:
Family: - StephenBFeb 12, 2024Guru - Experienced User
This looks like normal gigabit performance to me (~940 mbits/sec).
So I don't understand what problem you are trying to solve. Is the issue really about file transfer speed?
