carson
Jul 11, 2011Aspirant
ReadyNAS up and running
Well I got my Duo last Friday to replace my Stora that I was extremely unhappy with. The only real fault I can find so far is that the factory reset procedure isn't very well documented and that cost ...
arjoseph1
Jul 18, 2011Tutor
Good to hear that! You may want to visit ReadyNAS FAQ in the link below:
http://www.readynas.com/?cat=50
You will find a lot of helpful topics in it. I hope it helps next time. :)
