StructaLLP
Dec 04, 2015Aspirant
ReadyNAS upgrade to SSD
We currently have a ReadyNAS 516 with 6 x 1TB HDD's , we are potentially thinking about upgrading these HDD's to 6 x 1TB Samsung 850 Pro SSD's. I understand that the disks can be hot-swapped, but ca...
Dec 04, 2015Guru - Experienced User
When you insert the SSD drive, the NAS will reformat. So there's no issue there. The key question is whether the SSD has at least as many sectors as the HD you are replacing.
If it does, then your upgrade should work.
If not, then you'd need to rebuild the NAS (e.g. do a factory reset, reconfigure/install apps, recover data from backup).
StructaLLP
Dec 13, 2015Aspirant
Can you recommend a way I can find out the SSD sector count? As i have read in the past about SSD disks throwing out false information.
Thanks
Colin R
