StructaLLP
Dec 04, 2015Aspirant
ReadyNAS upgrade to SSD
We currently have a ReadyNAS 516 with 6 x 1TB HDD's , we are potentially thinking about upgrading these HDD's to 6 x 1TB Samsung 850 Pro SSD's. I understand that the disks can be hot-swapped, but ca...
StructaLLP
Dec 13, 2015Aspirant
Can you recommend a way I can find out the SSD sector count? As i have read in the past about SSD disks throwing out false information.
Thanks
Colin R
Dec 13, 2015Guru - Experienced User
The manufacturer's datasheet is probably the best way.
