rurobin
Oct 06, 2023Follower
ReadyNas V1 v1 (RND4000) - Err: Bad Firmware
I came home the other night and heard the fan running very fast. I powered down the unit. However when powering it on, the front screen gives error: Booting ERR: Bad firmwar After searchin...
Oct 07, 2023Guru - Experienced User
rurobin wrote:
Any other suggestions/options? I'd really like to keep/save the data on the drives. Hence, I have not attempted a factory reset option.
I think you will need a factory reset. But I suggest that you power up the NAS diskless, and confirm that you see a "no disks" status on the LCD screen - which will give some assurance that the flash is ok. RAIDar should also show this status. Label the disks by slot as you remove them.
Options to off-load data include
- connecting at least 3 drives to a Windows PC and using RAID recovery software (such as R-Studio)
- use tech support mode to manually mount the data volume and copy data off to USB drive(s).
After you get the NAS running, I suggest putting a backup plan in place. RAID isn't enough to keep your data safe.
