516withAES1
Jul 04, 2015Aspirant
ReadyNAS with AES Support
I do not need 10 Gbps LAN Ports included in 716X, the only model with AES support, currently. When can we expect other models with Intel processors supporting hardware encryption (AES)? Thank you in...
RX
Jul 05, 2015Luminary
As per the data sheet here: http://www.downloads.netgear.com/files/ ... -RN700.pdf - it says that the ReadyNAS 300/500/700 series supports AES 256-bit volume based encryption.
Your concern might be related on these forum links below:
https://www.readynas.com/forum/viewtopi ... 3&start=15
viewtopic.php?f=25&t=71516
