Ashgrove1's avatar
Ashgrove1
Follower
Jan 25, 2013
ReadyNAS won't turn on
I moved my ReadyNAS NV+ (3x 500 GB in X-Raid). Powered it down with power button. Un-plugged and re-plugged it in. Now the power won't come on. Where to start? At best I would like to get the system back running, in the least I would like to get the data off the drives. I would not consider myself tech savvy.
1 Reply
  • CaseyH's avatar
    CaseyH
    NETGEAR Expert
    Ashgrove1,
    Try an other power cable, and wall socket. If that doesn't work and your unit is still under warranty please call 1-888-Netgear option 4 and talk to support and let them know as we will probably need to replace your chassis.
ProSupport for Business
