Mjourdan
Mar 13, 2020Aspirant
ReadyNas102 status upgrading stuck
Hi folks, I tryied upgrade my ReadyNAS 102 to the latest firmware, 6.10.5; since then, the status is showing upgrading, it looks like something it is stuck.
Mar 13, 2020Guru - Experienced User
Do you mean 6.10.3? What were you upgrading from?
If it remains stuck, you'll need to pull the power and then reconnect it.
Mjourdan
I used the RAIDar software to perform the firmware update, and I followed its screen instructions.
However, investigating this behaviour, I downloaded the update package from website, and along with -arm.img file, there is another file with intructions and warnings. One of warning is: "ReadyNAS 102, 104, and 2120 systems must not be updated directly to 6.10.x from 6.3.x or older firmware. They must first be updated to either 6.2.5 or 6.3.5 then to 6.5.2 and then to 6.10.x.".
Unfortunately I dont remember what was my previous firmware. :(
