Mjourdan
Mar 13, 2020Aspirant
ReadyNas102 status upgrading stuck
Hi folks, I tryied upgrade my ReadyNAS 102 to the latest firmware, 6.10.5; since then, the status is showing upgrading, it looks like something it is stuck.
Mjourdan
Hi,
I already restarted several times. It is the same status, please consider the file attached.
sorry Im upgrading to firmware 6.10.3.
The power button is blinking.
Mar 14, 2020Guru - Experienced User
What are you upgrading from? If the firmware was very old, you might have skipped some intermediate steps.
USB recovery is likely the next step then. https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system#Manual_creation_for_ARM_systems
Do you have a backup of the data?
