McGarnagle
Feb 19, 2024Aspirant
Readynas316 apps
I currently use a Readynas 316 with 6 x 4TB drives. Even though the model is discontinued it has been operating fine so i have been ok with continuing to run it. Today i needed to reinstall the ...
Feb 19, 2024Guru - Experienced User
McGarnagle wrote:
Does this mean that from now on i will never be able to install the apps i need on this device?
You can downgrade to 6.10.9, that will re-enable the GUI install. You'd also need to apply the mods in this thread:
Posts 1 and 37 are likely the most useful to you.
