britesc
Mar 11, 2024Aspirant
ReadyNas524X - Lost admin Home Folder !!!
Hi,
Running ReadyNas 524X 6.10.10
Although I can login as admin, it appears that the admin home folder is not accessible anymore.
Is there anything I can do to try attempt recovery?
Like chkdsk, msadm etc??
Appreciate any guidance.
Thanks and kind regards,
jB đ
- SandsharkSensei
I've not (and won't) update to 6.10.10. But I'm wondering if anyone else has noticed this. It could be an unwanted by-product of eliminating ReadyCloud.
But it makes me wonder why you care. Using the admin credentials as your normal login is generally a bad idea, so you'd have little use for the admin home folder.
- britescAspirant
Hi,
Thanks for the replies.
If I ssh in then I get the following from /home
admin@Donkey:/home$ ls -lisa
ls: cannot access 'admin': Input/output errortotal 16
263 0 drwxr-xr-x 1 AUser users 712 Feb 23 2023 AUser
? ? d????????? ? ? ? ? ? adminIf I use the webgui and look at the shares I get a list of users of which admin is 1 of them.
If I then click on admin I get a progress bar that does not end and a rotating cog icon that continues for ever.
If this was NTFS I would say that the MBR File Descriptor has gone, but should be recoverable using various OS and 3rd party tools.
As this is a Debian derivative Linux I think that there is an inode problem.
Firstly is the RAID 5 constructed using mdadm in which case I would try some msadm tools etc.
If not any idea how the raid is constructed.
jB đ
? ? d????????? ? ? ? ? ? adminNormally it is recommended to log in as root when using ssh. But I do see my admin folder when I log as admin on a system running 6.10.10. Note this is an RN102, not an x86 NAS.
FWIW, the file system is btrfs, so no inodes. The home folder is actually on the data volume (you are accessing it via a mount point). You could try running btrfs check --force /dev/md127 (logging in as root) and see if that finds anything. If you try this, be careful not to access the data volume while the check is running. Otherwise you might crash.
