sbernhard
Apr 29, 2017Aspirant
readynasduo new disks but old size
i have started to run into the 1tb size (2* 1tb discs) and bought 2* 2tb discs. replacing and resyncing them one by one worked fine and all data is now on new discs but somehow they only have 1tb spa...
Apr 29, 2017Guru - Experienced User
What firmware are you running?
Try rebooting the duo, and see if that triggers the vertical expansion.
- sbernhardApr 29, 2017Aspirant
i have started a resync. wait of reboot? firmware is RAIDiator 4.1.15 [1.00a043]
- StephenBApr 29, 2017Guru - Experienced User
Wait for the resync to complete, then reboot. Wait a bit, and if you see no expansion beginning, then reboot again. BTW, hovering your mouse over the disk icon on the home page will give you some additional status (as will RAIDar).
Normally the v1's do need a reboot to initiate the vertical expansion step. Usually they prompt for it, but not always.
If this still fails, you can of course back up the data, do a factory reset, reconfigure the NAS, and then restore the data from the backup. Brute force, but there are sometimes performance benefits if you start with a clean slate.
- SandsharkApr 29, 2017Sensei
Is the ForceExpansion.bin add-on no longer compatible with the latest OS version for the V1's? I would think that would be a step before going to a factory default. I had to use that many moons ago. I looked at it with a hex editor and it has nothing in the header about archetecture or version compatibility.
