corkscrew22
Jul 28, 2021Aspirant
readynasduo RND2000 V2
Hi my readynasduo has two 1 x TB hdd fitted and was working perfectly. I had a sudden power outage and now it will not start up. It just has a flashing blue light. I tried the factory reset by pushi...
- Aug 05, 2021
corkscrew22 wrote:
I do have a UPS which as a power strip connected to it, which in turn I connect my sensitive network equipment to the NAS being one of them, I guess because the NAS shares the UPS i cannot take advantage of the NAS ups feature.
If the UPS has a usb connector, you can connect it to the NAS usb port, and see if it is detected. The NAS isn't controlling the UPS, instead it is monitoring it, and choosing when it should shut itself down. So it will not interfere with your other equipment being protected by it.
corkscrew22
Jul 29, 2021Aspirant
Sandshark
Jul 30, 2021Sensei
That is a Duo V1. Netgear originally used a "v1" or "v2" on the stickers to indicate minor board version differences on the Duo and NV+. They then created an entirely different line and re-used the "V2" designation -- creating a lot of confusion. The "real" V2 hardware and OS are entirely different from the V1, and they are in no way interchangeable.
So, you have likely been following the wrong instructions for using your NAS. But the screen grab you posted is of what appears to be a completely healthy Duo V1 with a volume just created. Did you re-install the firmware (which retains the volume), or do a factory reset (which wipes the drives)?
