corkscrew22
Jul 29, 2021Aspirant
readynasduo RND2000 V2
Hi my readynasduo has two 1 x TB hdd fitted and was working perfectly. I had a sudden power outage and now it will not start up. It just has a flashing blue light. I tried the factory reset by pushi...
- Aug 05, 2021
corkscrew22 wrote:
I do have a UPS which as a power strip connected to it, which in turn I connect my sensitive network equipment to the NAS being one of them, I guess because the NAS shares the UPS i cannot take advantage of the NAS ups feature.
If the UPS has a usb connector, you can connect it to the NAS usb port, and see if it is detected. The NAS isn't controlling the UPS, instead it is monitoring it, and choosing when it should shut itself down. So it will not interfere with your other equipment being protected by it.
Jul 30, 2021Guru - Experienced User
corkscrew22 wrote:To answer your question re model there is no ID on the front
There is. Sandshark is talking about this:
The circled part says "ReadyNAS Duo" on the original v1, but it says "ReadyNAS Duo v2" on the v2 model. However, we can also tell from the firmware - The v1 runs 4.1.x, and the v2 runs 5.3.x. So you have the original Duo (called a v1 here). The "v2" label on the back means it is "hardware revision v2 of the Duo v1". Very confusing branding on Netgear's part, and I'm sure support has been very unhappy about that for a very long time.
BTW, the firmware isn't the final release, that was 4.1.16.
corkscrew22 wrote: Do you have any idea what might of gone wrong with the power outage ? obviousley I have lost acces to my data (although I see the disk space is still used) but the shares I set up have gone
Generally speaking, the problem is caused by lost writes (which were cached, but never written to the disk). That can lead to a corrupted volume that can't be mounted. I always recommend connecting a UPS to the NAS to prevent this - the UPS ensures that the NAS can shut down cleanly when the power fails. FWIW, I once lost a volume on my own Duo due to an unexpected power loss. That triggered my investment in UPS.
I think there was a good chance we could have recovered the data if you hadn't done the reset, but it's hard to say for sure. RAID Recovery software (perhaps R-linux for Windows) might still be able to find it. But if you want to try that, then power down the NAS, as the more disk writes that happen, the more unlikely recovery is.
If you did a factory default (and it sounds like you did), then the disk space isn't used, and the data is gone. The disks are formatted as part of the process. There is some space usage that shows up in Frontview, but that isn't real - it's reserved by the NAS. If I recall correctly, it will show about 20 GB of used space after setup completes. Your setup screen is showing 0% used.
corkscrew22
Jul 31, 2021Aspirant
thanks that clears up the version issue and thanks for the tip on the firmware maybe I will update but read on....
The NAS is not allowing share access I dont understand what has gone wrong below are the steps I followed.
Prior to this power outage everything worked perfectly I was using the NAS as storage for TV shows , videos and music. I could access all from my raspberry pi using kodi, also access with my nvidia shield using kodie to stream from the NAS. Both used NFS to access the NAS with no issue at all. My desktop PC running Linux Mint 20.1 I used to transfer files to the NAS from the file manager.
Tha NAS shares were mounted by way of fstab in the desktop and the Raspbery Pi.
Now the NAS shares will not mount at all and i repeated the exact same steps before the power outage.
The steps I have taken are as followsFactory reset
Access NAS via web interface deleted the default shares
Manually set up a share using NFS (screen shots attached of the NFS settings)
edit fstab on desktop to the same as when it was working previousley
- StephenBJul 31, 2021Guru - Experienced User
Did you have any user accounts set up on the NAS before? I'm wondering if you previously set the owner/group and perhaps some other info in advanced options.
Did you try using showmount on the clients (as root)?
# showmount -e nas-ip-address
If you are using the NAS name in the mounts, you might try using the IP address instead.
- corkscrew22Aug 02, 2021Aspirant
I would of thought that a factory reset would of deleted any users or permisssions. I am using ip to mount the share
fstab entry using ip address
192.168.2.9:/TV /media/NASduo/NASTV nfs noauto,x-systemd.automount,x-systemd.mount-timeout=10s,I havent changed anything and bizarrley it just started working again....so fingers crossed below are my nfs settings
Should i upgrade the firmware?
- StephenBAug 02, 2021Guru - Experienced User
It reformats the disks, and then reinstalls the OS, so everything goes back to the defaults.
I would - I don't think there are any bug fixes, but there were some security updates that it would be good to have.
It's conceivable that the 10s timeout might have kicked in.
Do you have spindown enabled?
Was the NAS under heavier load when you first tried the mount (perhaps still resyncing)
