corkscrew22
Jul 28, 2021Aspirant
readynasduo RND2000 V2
Hi my readynasduo has two 1 x TB hdd fitted and was working perfectly. I had a sudden power outage and now it will not start up. It just has a flashing blue light. I tried the factory reset by pushi...
- Aug 05, 2021
corkscrew22 wrote:
I do have a UPS which as a power strip connected to it, which in turn I connect my sensitive network equipment to the NAS being one of them, I guess because the NAS shares the UPS i cannot take advantage of the NAS ups feature.
If the UPS has a usb connector, you can connect it to the NAS usb port, and see if it is detected. The NAS isn't controlling the UPS, instead it is monitoring it, and choosing when it should shut itself down. So it will not interfere with your other equipment being protected by it.
Aug 02, 2021Guru - Experienced User
corkscrew22 wrote:
I would of thought that a factory reset would of deleted any users or permisssions.
It reformats the disks, and then reinstalls the OS, so everything goes back to the defaults.
corkscrew22 wrote:
Should i upgrade the firmware?
I would - I don't think there are any bug fixes, but there were some security updates that it would be good to have.
corkscrew22 wrote:
192.168.2.9:/TV /media/NASduo/NASTV nfs noauto,x-systemd.automount,x-systemd.mount-timeout=10s,I havent changed anything and bizarrley it just started working again
It's conceivable that the 10s timeout might have kicked in.
Do you have spindown enabled?
Was the NAS under heavier load when you first tried the mount (perhaps still resyncing)
corkscrew22
Aug 05, 2021Aspirant
No I did not have spin down enabled to be honest i did not know it existed, i also found the options to power down at set times so i can set it up to power down during the night. In my part of the world power outages are common place.
- StephenBAug 05, 2021Guru - Experienced User
