boromb
Jul 21, 2011Aspirant
ReadyNasDuo unreachable. Can't shutdown on powebutton
Hello, I have a serious problem with my readyNasDuo. I has been working quite good for a while but now it can be reached or shutdown. It doesn't react on pressure on the powerbutton. In the ad...
PapaBear1
Jul 21, 2011Apprentice
Is the Duo a backup of images stored elsewhere, or are they only on the Duo?
To shut down via the power button, you need to press and hold for 5-10 seconds. Brut power (pulling the plug) will aways work, but I would hold off doing that just yet.
