boromb
Jul 21, 2011Aspirant
ReadyNasDuo unreachable. Can't shutdown on powebutton
Hello, I have a serious problem with my readyNasDuo. I has been working quite good for a while but now it can be reached or shutdown. It doesn't react on pressure on the powerbutton. In the ad...
boromb
Aug 10, 2011Aspirant
Hello again,
After some phoning with Netgear support in Sweden I have come a bit longer.
My data is still unreachable but my nas works after reset and new harddrive.
1. I bought new hard drive
2. I installed it in bay 1 and all other disk taken out
3. I started readyNas with reset button pushed down
After some minutes my Nas was working again.
After that I took out the new drive and tried with only old bay2 drive. Nas won't start.
I tried the same thing with old bay1 hard drive withous success.
Nas wont start and I can't reach it with RAIDar.
I suppose theres some trouble with my disks.
Is there a way to connect those drives to a Windows PC to see if theres some data that
I can copy?
A guy on Neatgear support sad that it may be possible with a pc running Linux.
Hope there's a way,
Best regards!
I can copy?
Hope there's a way,
Best regards!
