briandconnolly
Dec 14, 2016Aspirant
ReadyShare to ReadyNAS
I own a R6220. I want to go from ReadyShare to ReadyNAS. What is the optimal way to attach a NAS server to the R6220? Thank you.
Dec 15, 2016Guru - Experienced User
There is only one way to attach it - which is via ethernet. The "N" in NAS stands for "network".
ReadyCloud would be managed from the ReadyNAS, not the router.
FramerV
Dec 18, 2016NETGEAR Employee Retired
Hi briandconnolly,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- briandconnollyDec 18, 2016Aspirant
Got it. Solved. Thank you.
