bospe
Oct 08, 2016Aspirant
Recover / acces to data
Hi I have trouble to get my data out of the raeadynas 102. I can´t open the Raidar or the folder via browser. The disc might be bad.. But I wanna try to boot in the volume read only mode, but th...
Leia
Oct 08, 2016NETGEAR Employee Retired
Firstly, did you create X-RAID volume or non-XRAID volume? If it was non-XRAID volume, what RAID type you created?
For booting in Volume Read Only mode you can follow this: Boot menu of Volume Read Only
bospe
Hi, and thanks for your answer
I think i used an raid 5, but I don't know now. It is aged since I looked into it
But the disk did run as back-up for each other
- bospeOct 08, 2016Aspirant
and the user guide, does NOT tell how to get nto the boot menu for volume read only. Its just mention the possibilety to do so...
Rgards Bo
- mdgm-ntgrOct 08, 2016NETGEAR Employee Retired
See p.17 of this manual: http://www.downloads.netgear.com/files/GDC/READYNAS-100/RN_OS_6_Desktop_HW_UM_12Oct2015.pdf#page17
- LeiaOct 08, 2016NETGEAR Employee Retired
If you didn't destroy the default "data" volume, and create a new one, it should be RAID1 in your RN102.
If you are sure the disks mirror for each other(it means you installed 2*1TB disks, and you got a 1TB volume), and after booting in volume read only mode the volume is still unable to be mounted, then you can try:
1. Power off your RN102.
2. Cold remove one of the disks(if you know which one is bad, just remove the bad one).
3. Keep the other disk in the box and boot up.
It might work if one of your disks was still healthy. Please power off your box before removing the disk. Good luck!
tried that. but no succes.
I says in the raidar, multible disk errors
- StephenBOct 08, 2016Guru - Experienced User
Do you have email alerts configured? If so, did you receive any warnings about a failing disk?
You can try connecting the two disks to a windows PC (perhaps using a USB->SATA adapter) and run the vendor diagnostics on them. Seatools for Seagate, Lifeguard for Western Digital.
If the disks can be read at all, it might be possible to clone them to working disks and get some of the data.
