pwarlike
Jun 07, 2013Aspirant
Red Led In ReadyNas Pro 6 Motherboard
Hello There is a red led activate in the motherboard of my ReadyNAS Pro 6 between the micro and the memory Is normal?? Thanks!
fastfwd
Feb 22, 2014Virtuoso
The LED is just an indicator that the power is on. It is placed there in the hope that seeing it will prevent you from removing the CPU or RAM (or performing other similar operations) without first switching the power off.
