Ouija's avatar
Ouija
RedyNAS 214 initial setup problem
I got a ReadyNas 214 for my birthday yesterday.  Please bear with me as it's my first NAS device, but I do have a complete home network that I wired myself and am well versed enough to have multiple ...
  • StephenB's avatar
    Nov 03, 2016
    You do have 90 day phone support for installation.  I think you should use it - the LCD gooblegook suggests something might be wrong with your hardware.
    Go to my.netgear.com and register the unit.  Then you should be able to contact support from there.
    Ouija wrote:
    I put in 1 (almost brand new, a month old) 3TB Segate Barricuda (ST3000DM001) drive. and after several hours It displayed an IP address on the front display.
    Those particular drives have a high failure rate in RAID arrays.  If you can still exchange the new ones, I'd suggest either 3 TB Seagate IronWolf or 3 TB WDC Red drives.  Both are intended for NAS, and posters here seem happy with both of them.  You can mix/match - so you can leave the older DM drive in the array.
ProSupport for Business
