JovannB
May 19, 2017Tutor
reestablishing SMB-Connections lasts up to 30 minutes
Hi,
I've a 314 NAS (mounted as drive M:\) behind a HP-Procurve-Switch, for some reasons (ransomwareprotection) I disconnect that certain switch port by snmp-command - thats no problem.
Later then I reestablish that connection - switching that certain switch-port on.
Then it lasts between 10 and 30 minutes, till I can access the NAS by drive-Letter which is M:\.
Interesting is, that after switching the Procurve-Switchport on, I can access that NAS Admin-Page immediatelly, but why not the drive M: which is connected via SMB to my Windows system.
Whats the reason for that behaviour and/or is there configuration to improve - shorten that time afer switching port on an ability to connect to M:\ - the situation ?
J.B.
Hi,
I installed the latest Firmeware (6.7.4.) on my NAS some days ago and now I thought to test whether something has changed relating to my problem.
Indeed, when I disable my Switch-Port (where NAS is connected to) and then (re-) enable that Switch-Port (HP-Procurve-Switch, disabling/enabling via SNMP-Command) then it lasts 10 seconds!!!! until I have a SMB-Connection to my NAS.
Amazing, thank you for your effort spent in my case.
J.B.
- mdgm-ntgrNETGEAR Employee Retired
Odd. Can you reproduce the issue then send in your logs (see the Sending Logs link in my sig)?
- JovannBTutor
Hi,
as far as I can see in the logs there is nothing in particular - I jotted the time down when I did my tests 10:32 and at that time there no log-entries
Is there a deeper inview into the logs ??
Where to upload or sent the logs too ??
J.B.
The article linked to in my sig explains how to provide the logs.
